To use Siri with ChatGPT, you can set up a Siri Shortcut that allows you to interact with ChatGPT using voice commands. This can be done through the ChatGPT app, which is available on the App Store, or by integrating OpenAI’s API for a more customized experience.
By creating a shortcut in the Shortcuts app, you can trigger ChatGPT with a simple phrase like “Hey Siri, Ask ChatGPT,” making it easy to access AI-generated responses hands-free. This integration enhances Siri’s capabilities, allowing for more advanced and conversational interactions.
Here’s how to do it:
Method 1: Use OpenAI’s ChatGPT App with Siri Shortcuts
1. Download the ChatGPT app
• Install the ChatGPT app from the App Store if you haven’t already.
2. Enable Siri for ChatGPT
• Go to Settings > Siri & Search > Find ChatGPT in the app list.
• Toggle on Use with Ask Siri and Suggest App options.3. Create a Siri Shortcut for ChatGPT
• Open the Shortcuts app.
• Tap + (New Shortcut).
• Tap Add Action > Apps > ChatGPT > Ask ChatGPT.
• Customize the shortcut phrase (e.g., “Ask ChatGPT”).
• Tap Done to save it.4. Use Siri to activate ChatGPT
• Say “Hey Siri, Ask ChatGPT”, and then speak your question.
• Siri will open ChatGPT and input your query.Read more: Walking to lose weight: Two gadgets to help increase your step count in 2025
Method 2: Use ChatGPT via Siri and OpenAI API (Advanced)
If you have access to the OpenAI API, you can create a custom Siri Shortcut to interact with ChatGPT via API.
1. Get an OpenAI API Key
• Sign up at OpenAI.
• Get an API key from the OpenAI developer dashboard.2. Create a Custom Siri Shortcut
• Open Shortcuts > + (New Shortcut).
• Add “Get Contents of URL” action.
• Use https://api.openai.com/v1/chat/completions as the URL.
• Set Method to POST.
• Add Headers:
• “Authorization”: “Bearer YOUR_OPENAI_API_KEY”
• “Content-Type”: “application/json”
• Add a Request Body with a ChatGPT query.
• Add a Text Output action to display the response.3. Activate the Shortcut with Siri
• Assign a voice command like “Chat with AI”.
• Now, say “Hey Siri, Chat with AI” to use ChatGPT via API.In conclusion, integrating Siri with ChatGPT provides a seamless and efficient way to access AI-powered responses using voice commands. Whether through the ChatGPT app with Siri Shortcuts or a custom setup using OpenAI’s API, this integration enhances Siri’s functionality, making interactions more natural and conversational.
By setting up a simple voice command, you can quickly access ChatGPT for assistance, information, or casual conversation, improving the overall user experience.
